TwinTurbo.NET: Nissan 300ZX forum - My transmission is a bitch to get into first when cold
nissubaru
on January 29, 2019 at 9:13 AM
The '98 spec trans replaced the previous model
posted by JMartz
on January 29, 2019 at 06:35 AM
Like you said, I usually have to wait until I'm at a stop. It gets better though once the car warms up. I plan to bleed the clutch and replace the trans fluid over the winter though so hopefully that addresses it.
98+ spec tranny question
yfz450chuck
21:30:57 01/28/19
JMartz
06:35:57 01/29/19
My transmission is a bitch to get into first when cold -
nissubaru
09:13:45 01/29/19
Those are the exact same symptoms I had and why I
JMartz
09:57:52 01/29/19
That's actually a design feature.
01:17:22 01/31/19
Re: The '98 spec trans replaced the previous model
Metacom
11:07:15 01/29/19
I wonder if there is something that can be done to
JMartz
14:51:22 01/29/19
Re: I wonder if there is something that can be done to
Metacom
15:36:07 01/29/19
Not sure I can agree with a lubricant change
JMartz
08:03:37 01/30/19
That's a diff. oil - not a transmission fluid.
01:22:19 01/31/19
Article
JMartz
08:42:40 01/31/19
I've read that and it agrees GL5 doesn't belong in our trans (n/m)
11:28:45 01/31/19
Good thing I have only put a handful of miles
JMartz
08:09:57 02/01/19
Been there with Mobil1 like said it is a GL5 and not >>
ZUL8TR
15:03:00 02/12/19
[like] (n/m)
09:46:07 02/22/19
Agreed (n/m)
01:22:36 01/31/19
Why do you need to be in 1st?
01:19:04 01/31/19
Correct (n/m)
01:17:58 01/31/19
